Can i use a 7cm gasket on a 14b ?
Dsmj89
3,249
14
Nov 11, 2008
Miami, Florida
Just as the title states. I am looking forward to replacing my gaskets on my turbo and was wondering if would be able to use a 7cm stainless steel gasket on the 14b/2g mani without any problems ? Or will i have to port ?
I also want to eliminate the seal ring as well, i re-used it cause i'm still running on stock gasket.
Okm12346 thanks, i know it'll work, i just don't want to have any exhaust leaks by just slapping it on there you know.
Before i start ordering gaskets can anyone else confirm i won't have a leak if i order a 7cm stainless steel gasket for the turbo ? Thanks, i need to know asap i need to order today.
I would recommend you get the OEM style multi layer gasket. The SS gaskets can warp and crack.
Liquid you are talking about the manifold to turbo gasket right ?
