Can I use a 1g mas in my 1gnt?
mfilion
Mar 22, 2006
Fairport, New York
I dropped mine and now I have a very rough idle.
I know the one for the turbo models has an extra wire, but that's all I can seem to find. thanks
Edit:i know my profile says i have a '96 NT, but my other car is a '91 2.0 DOHC
You can but youd have to cut the wires and splice in the turbos plug which is slightly bigger since it houses a 7th wire and then youd have to run that 7th wire back into the ecu to say pin 109 or something ( dont take my word on that its probably not that pin im just giving you an idea you can find that out on vfaq.com ) and on top of that the n/t ecu wont kno how to read that 7th wire once you got it in the proper pin out therefore then youd need to get a 91-94 turbo ecu on top of that and there ecu has way less timing advance for the boost factor which would make you slower n/t, so then youd want to hope it was an eprom so you could get it rechipped back to n/a status but have it tuned out fully while your at it since thats a feature on these dsm chips and if everything was hooked up/ spliced properly then yea it will work fines.
