4gfun
Supporting VIP
- 2,012
- 56
- Dec 10, 2007
Ask Me,
Virginia
I want to know if I could start the car to make sure the motor is still good after going through a pp/clutch/flywheel swap.
I had to use more heat on the flywheel bolts than I cared to and turned the crank pulley backwards a few times accidentally when using the crank key and breaker bar for leverage when removing the flywheel bolts.
I am guessing that the odds I wrecked the engine are low but I want to make sure before I put any more time/money/work into this car.
I would also like to start it for a little while since it has been sitting here for 4 months and I don't know when I will have time to add these fluids.
I don't see how this can be harmful as long as I don't put it in gear.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
