carbonfire
- 175
- 1
- Aug 23, 2004
Waterloo,
Iowa
Well that is my question... how to and if I can block off my water lines on a 1g that go to the turbo and than the return line.... If so what size plugs do I use? I was doing some reading and it appears that is can be blocked off and not looped like it is on the second gens but I dont know what size plugs to use... My manifold for my T3T4 will be here Tuesday and I want to be ready......
I just stuck a screw in the hole and jb-welded it..
That also has not leaked either. So it worked fine for me. But yes, You can plug them, However you decide to do it.
but is the metal feedline bolt to waterpipe reverse threaded. I tried to turn it out with my 17mm flare wrench even after heating the waterline boss and would not budge when turning clockwise form the top (would be counterclockwise from the bottom).
