truwarrior
- 1,422
- 6
- Dec 19, 2002
I'm installing a EVOIII in my GST following diag from the hanes manual. The water lines don't line up right...the bottom return lines (siliver color) rubber hose gets smashed by the motor mount and wastegate while the top water line or the water feed...points upward while the water feed from the block it 4-5 inches below it...
This is the only way I found to hook these lines up...did I do something wrong?
