Can engine timing be good, but not good enough?
RallyEclipse98
967
29
Jul 31, 2007
Dallas, Texas
The car is a '99 420a.
I have my timing set. It should run fine when I start the car tomorrow but I have heard from somewhere that if the timing is just a couple teeth off, the car will still run. After the engine revs up under load, the car will then lose power. Is that true? I just don't want the car to run fine in the garage and then after I bolt all the mounts, etc. back up, only to have the car fall on its face down the road. Any thoughts?
Thanks for your time.
All marks are good. Everything went together just like the FSM said it does. It would have only taken me one try but when I was bringing the crank back to TDC, I was talking to someone about celebrity net worths and I cranked too far advanced and had to reset the belt. After that mishap it took about an hour or so to get right.
Thanks for the advice. I will bolt everything back up once I turn the engine over by hand a few times.
