Can DSMlink control boost?
Because the car isnt physically able to. Thats like telling my computer to turn on without pushing the power button. NOW. If you have a EBC. Then yea you can. Because the electronic device i designed for both a electronic and manual use. see what im getting at?
James :laser::talon:
The stock ebc has only a narrow range of control. When it's closed, boost level is limited to the activation pressure of the waste gate actuator. When it's open, it allows a few pounds more boost to the intake before sufficient pressure reaches the waste gate actuator to open it. It's not an on/off switch for the waste gate. To control boost electronically, a separate solenoid and pressure sensor are needed.
its hard to understand what you're saying. But, either way, dsmlink wasnt made for it in the first place. And then, even if it was, you need a way to control the MBC. A device like a electronic boost controller. It just wont happen.
You have a line from compressor outlet into the MBC
the MBC is set to say 18 psi
line out of MBC to boost solenoid
line out of boost sol to wastegate.
The very min amount of boost would be 18 psi, but just as the stock ecu bleeds off boost pressure couldn't dsm link to the same thing? I can't belive that link couldn't do that. I am not suggesting that it have a range of 10-45 psi, but I think it is very possible to have range from say 18-30, by bleeding different amonts of air off. It would just take boost estimate and air flow data to sense how much boost there is and how much to control. It could also feature a reduced boost feature as most ecus these days do, much the same as DSM link NOS feature.
Later Dr Turbo
