95EclipseGST
- 406
- 1
- Mar 1, 2002
Kansas City,
Missouri
1) I was wondering if bad turbo seals can be causing my car not to spool until 4800rpm? I will be at like 1-2 psi WOT and i wont get boost until all the sudden at 4800rpm it will quickly hit 15psi. I AM burning a ton of oil, but also have just a few drops on the ground in the garage.
2) Can bad turbo seals cause oil to leak onto the ground?
3) Can bad turbo seals cause oil to be in my coolant bottle?
4) Also, can this possibly be causing my car to overheat at idle? I have a Fluidyne and brand new FAL shrouded cooling fans hooked up to where both fans are on at all times. When i am at IDle for 10 min, it will overheat. When i start driving, it will quickly go down to normal. Could bad turbo seals cause this? I have all good cooling equipment, so im wondering if turbo seals could cause this as well.
