Can a dirty air filter reduce gas mileage?
i want to take this another step further for my own gain of knowledge
If the throttle is not wide open so no open loop, the air filter (not so dirty you can grow tomatoes in it.) is restricting air to the motor, wouldn't less air, mean less fuel. Just because the throttle plate isn't is controlling the air flow doesn't mean something else can't. I also realize the tps is taken into affect, but it really wouldn't matter till wide open throttle. The o2 will still try to change the a/f to match the ratio with less air.
so i am wondering if there is cases where this will not apply for decreasing gas mileage
every one always says yes, but never really states why
It takes a helluva lot of dirt to close up an air filter enough to affect mileage. Compared to the intake, they're absolutely huge in surface area. Also, fuel injected motors don't have the same reaction to strangulation as a carburetor: you don't start sucking in raw gasoline when the air supply starts getting choked as you do through a carb.
If you feel guilty about your air filter, replace it. But it won't fix a gas consumption problem.
So i just realized that I have changed my air filter since I bout my CAI almost 2 years ago. Would I notice a difference in the way it runs if I bought a K&N?
Its hard to say because my stock filter was so dirty that when i changed it to a dry filter and added a hard intake pipe, i went from 325 miles on a full tank to now I'm getting 388 miles on a full tank
id say a clean air filter might help abit better airflow?
If this is a question, we appreciate that you actually searched and replied to a similar thread which already existed on the topic.
If this is a statement, I'm not exactly sure why you responded to an 8+-year-old thread to on a common-knowledge topic.
+1. I've ran several cars with moderately dirty filters. Swapped to new, no discernible difference in mileage. It's one of those easy fixes auto parts chains love to push for sales, that don't really hurt as bad as they make it sound.
