falcon8r
- 205
- 0
- Sep 15, 2009
kalispell,
Montana
Well I have a bit of a question. How does the camshaft relationship affect engine idle vacuum ? The reason I ask is I have Delta's 264/272 camshafts and I think I can set it up two different ways. With the ex cam slightly advanced , rocked counter clock, the car idles at 7-9in. vacuum and has a lope and a doggy bottom end. I put it together with the ex tipped forward , it does not line up exacly as the block/head have been machined. It has 11 or more inches of vacuum and is more responsive. The top end screams either way. Can the cams be changed a tooth without tearing the lower cover off? Use the rod/tensioner combo and slip the cam a tooth ? I think the car ran better the way I had it. I like the low end. Don't want to have to shell the $$$ for adj cam gears right now. Tres....
