1fast97gsx
- 4,517
- 17
- Jul 6, 2003
Orland Park,
Illinois
What type of compression numbers are you guys getting with hks 272s? I was getting a solid 180 all the way across before the cams ( 9:1 pistons with thicker headgasket ), but once I put the cams in I only got 155 all the way across. I know its normal for static compression to drop, but 25 psi per cylinder??? My vacuum at idle is also only 11. I was expecting more like 13-14?
