Resolved Camshaft angle position housing gasket/o-ring?
gho5tone
324
6
Aug 14, 2010
Rosemead, California
Hi, I have search many threads for my answer and vendors for the part about the CAS gasket between the plate and the housing but I could not find the answer nor part.
So, I was wondering if there is a gasket between the plate and housing of the CAS for the 2g 98 eclipse gst.
If so, could I get the part number and locations to get it such as autozone etc or at least a indication of where to get it.
If not, what is the proper way to seal it because I have a very small leak at the bottom of the plate.
Also, Can I use just about any type of PCV hose or does it use only crankcase vent hose?
Thanks! :)
thanks! I was wondering if there was a gasket because my mechanic blasted it with RTV :hmm:
It's all right, now I can learn more about the DSM because I'm going to fix his mistake! :D
