camber and toe settings
dan2288
577
Sep 9, 2006
Shillington, Pennsylvania
I dropped my car about 2 inches and will be getting an alignment soon. Its a 2g awd. Im pretty sure the toe should be at 0 on all four corners. What should the camber be set at? I want it to handle good around the turns. Also ### about the caster? Is that important?
Caster is unadjustable on 2g's (without adjustable balljoints or changing the compression arm bushing) and camber is adjustable in the rear with a shim kit only - save a buck, and use a few washers to shim the rear camber back to normal. Front camber you can leave a little extra negative, as it is beneficial. My car is 1.5" lower, and I'm ok with the front camber where it sits without adjustment. With a 2" drop, it may be a bit too negative. It's up to you if you want to invest in the parts needed to fix the front camber.
http://www.dsmtuners.com/forums/handling-tech/169442-factory-alignment-specs.html
http://www.dsmtuners.com/forums/handling-tech/169559-autocrossing-alignment-2g.html
http://www.dsmtuners.com/forums/handling-tech/169557-street-low-tire-wear-alignment.html
Fix the alignment as soon as possible - the horrible tire wear is faster than you think. 2 weeks can ruin your tires.
wow thats a lot of good info there. Thanks for the post
