How long will tires last with -2 camber and perfect toe?
clipse0001
249
4
Jul 26, 2005
blacksburg, Virginia
-1.6 front
-2.2 rear
factory spec toe
crappy nankangs almost new
how fast should i get a camber kit?
-Anton-
Yesterday. Seriously though, it seems like common sense to me. How much is a camber kit compared to a new set of tires?
I've had 2+ deg. all last summer,:rolleyes: (4000 mi.) & saw very little extra wear, with reasonable toe specs so it will probably be ok, short term. That said, I'd (I am) correct it asap for wear & handling reasons. Toe is what will kill tires in a hurry, cause they would be always "scrubbing".
Did you have neogens last summer? Those will take up to 2 degrees easily. I think they are meant to be used with 1-2* camber. I think I will pick up a camber kit for the front and back this coming week.
Does anyone know what is the best/cheap kit to use? I need front and back.
Thanks for the help
-Anton-
Thanks for the help
-Anton-
Yes on the neo gens. I can't help on the camber kits though, since I'm making upper control arms myself, plus I've got a 1g. Yer welcome.
