Cam suggestions
Blownuptsi92
60
Oct 5, 2011
Fenton, Missouri
I am getting real close to start rebuilding my motor. I am shooting for 300-350 hp to the wheels. Heres the issue I want a 272/272 BC cam in here I like the way it sounds and dont want to run stock cams. What would be needed to put one of these in a 1g head, what should be changed to make this work? Im new to the dsm world so any suggestions would help. Thanks.
You don't need cams for 300-350 whp. If you don't plan on going any higher on your hp goals I would suggest some 264s, that way you don't have to do any supporting mods to your valve train and you can remain safe.
Yup - nothing else needed, unless you are going to rev higher, then you do need to upgrade your springs... and I agree, I like the FP cams better than BC's too.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
