Cam Selection 272's or 280's?
swarm
DSMtuners Server Guru
466
Mar 26, 2004
Spokane, Washington
Hi all. I am here looking for some advice. First some background on the car:
-- Electronics
AEM UEGO WIDEBAND O2 SENSOR/GAUGE
GREDDY TURBO TIMER
GREDDY ELECTRONIC BOOST CONTROLLER
AUTOMETER EGT GAUGE
AUTOMETER BOOST GAUGE
AUTOMETER OIL PRESSURE GAUGE
AUTOMETER COOLANT TEMPERATURE GAUGE
AUTOMETER BATTERY VOLT GAUGE
REDLINE STANDALONE ENGINE MANAGEMENT
-- Fuel
AEROMOTIVE AFPR
LIQUID FILLED FUEL PRESSURE GAUGE
AEM HIGH FLOW FUEL RAIL
FIC 1000CC FUEL INJECTORS
ALL STAINLESS FUEL LINES
-- Forced Induction
FRONT MOUNT INTERCOOLER
GREDDY TYPE-S BLOW OFF VALVE
FORCED PERFORMANCE GREEN MODEL TURBO
TIAL 38MM EXTERNAL WASTEGATE
-- Intake
3" INTAKE PIPE
-- Exhaust
EVO 3 EXHAUST MANIFOLD
EVO 3 O2 HOUSING
3” TURBO-BACK EXHAUST SYSTEM
-- Top End
ARP HEAD STUDS
MILD PORT/POLISH
3G LIFTERS
HKS 264/272 CAMSHAFTS
CROWER TITANIUM VALVE SPRING RETAINERS
COMETIC HEAD GASKET
-- Bottom End
ARIAS PISTONS
EAGLE H-BEAM RODS
ARP MAIN STUDS
ARP ROD BOLTS
CLEVITE 77 BEARINGS
-- Drivetrain
TRE RACE TRANSMISSION
ACT 2600 CLUTCH
FIDANZA ALUMINUM FLYWHEEL
TABOO SPEED SHOP CLUTCH FORK
SHEP VISCOUS COUPLER ELIMINATOR FOR DYNOING
-- Suspension
KYB AGX ADJUSTABLE SHOCKS
-- Exterior
CUSTOM BLUE PAINT
HID CONVERSION
BMW E36 M3 FOGLIGHTS
CARBON FIBER HOOD
CARBON FIBER GAS CAP
-- Miscellaneous
METHANOL INJECTION W/ 12GPH INJECTOR
THREESPEED SCATTER SHIELD
ABS REMOVAL
CRUISE CONTROL REMOVAL
PROTHANE MOTOR MOUNTS
This is my current setup. Yes I know a lot of that has nothing to do with this question - I copied/pasted from notpad. Anyhow on to the question.
I currently have HKS 264/272. I want to go to 272/272 or 280/280. How harsh would my streetability be on 280's? I am currently on Fp green and stock intake manifold, but those will be changing to JMF SMIM and a big turbo in the not too distant future. I don't feel like taking the head apart again since I am currently building the motor/head. I still want this thing to be streetable, but I want it to perform best on the track. Discuss...
My fp2Xs (fp2 cams are like 272s but a little more up top) are fine for the street for me. But that's just me. It isn't annoyingly sluggish down low for me. But it's rare to get great street performance and still have it 'perform best on the track'.
A set of adjustable cam gears can give you what you want. Advance the cams slightly for street time. And set them back for track. . . . other than that, you can go stroker or just stick with the turbo you have:D . A bigger turbo likes more cam than what you have. It will insure not running at the surge limit.
