cam seal leak?!
AnthonyRounds
Jul 11, 2012
Norman, Oklahoma
Okay, I have a 94 gs, i noticed i was using oil. so i started to look around and saw that my cam gear seals are leaking. i have a buddy that owns a DSM shop. but he still wants like 400 to do it. is there anything i can do, besides dump $4-500 to do the job?! pm me or comment :notgood:
If u do the work yourself u save about $370.. OEM seals are like 30$ and if u are mechanically inclined you can do the job in 3hrs give or take. Personally I would do it myself.. If you do infact do the cam seals yourself then I would make sure u understand how to do the timing belt correctly. Pretty simple to do but most people make it more complicated. Save yourself the fees at the shop and learn about your DSM :thumb:
If you don't feel comfortable doing the timing belt then I recommend someone who does as your 4g63 is also a interference motor. meaning valves can tap if the timing is off and then it gets costly
I know how, its just the timing part. and thats the killer. but i dont have to money to drop 500 on it. plus I already have the seals and the tool to take off the timing belt
its pretty easy man just got bye the auto manual and you will be fine go ahead and replace the time belt to
and tens.
dang phone just go bye the manual i meant to say
its real easy exhaust cam need to be at 3 o'clock and intake cam need to be at 9 o'clock and crank at 11 o'clock do not turn the engine back wards only forwards there there are lil marks on the cam and the crank has i mark to but it like a lil then peace of matal on the crank that has a knotch cut into it just post up pic when you set he timing and i will tell you if it right or wrong
VFAQ
Click on "Engine" at the top and under "Timing Belt" it explains how to do a 1G T (turbo), 2G T, and 2G NT. If it is for the 1G NT on your profile, I'm not sure if that is different or not than the 2G NT.
