Cam moved after removing tbelt, help plz
rivet0r
490
Sep 22, 2002
Anyways, I'm in the middle of doing a tbelt job on my car, and to make a long story short, after I removed the belt, the cams are off. When I try to put it back in time, it gets hard and once I let go it goes back to where it was. How can I get the cams to stay in place?
Any help is greatly appreciated, I want to get this done ASAP.
-rivet0r
http://www.vfaq.com/FAQlocator-index.html
-May be necessary to BIAS / mis-Time Exhaust Cam ONE Tooth Clockwise - Belt Tensioning will roll it back into time.
-Don't forget to apply soft Loctite or RTV to Tensioner Fasteners & apply Final Torque.
-Run ALLTHREAD Tool in until Tensioner Bottoms
-Basically you preload the Eccentric Tension Pulley enough to achieve the correct Tension setting...
-PRE-LOAD the Eccentric Tension Pulley slightly & snug Pulley Bolt
-Back off ALLTHREAD TOOL letting the Tensioner Tension the T/Belt
-Check Tension setting with Pin
-If gap is too large you have UNDER TENSIONED BELT
-IF UNDERTENSIONED put a LOAD under Tensioner Pulley with long Screwdriver & SIMULTANEOUSLY loosen Pulley Bolt, putting more Tension on Belt & Snug up Pulley Bolt while applying Load.
- Check Tension setting with Pin
- If Pin checks Sat apply Final Torque to Pulley Bolt & RECHECK TENSION SETTING (I used soft Loctite on this Bolt too).
- If Gap is too small you have OVER-TENSIONED Belt
- Don't forget you have ALLTHREAD tool there to help you hold what Tension you've got - but don't forget to back it off at least a few turns when appropriate so Tensioner can apply Tension.
- Install just enuff Belts to run Water Pump - attach Battery charger & run Motor with NO Timing Covers
-Immediately when you get it running Reset Base Timing & Idle as it comes up to Full Running Temp - Start off with CAS at middle of adjustment - Check for Coolant Leaks - Check your new Water Pump & O Ring, etc, etc...
- After a good hot idle or 2 re-check Tension with Pin & Button up Covers if all is SAT - expect to see one good stretch as Belt sets in & one good re-setting after initial idle
