cam gears installation with t4z hta t88 T4 twinscroll
dmaffo
59
Feb 9, 2009
toronto, ON, Canada
Just installing last of my parts before I take car to be tuned. I have not read much on my new turbo, or its full capacity. Very few have had them, and what I have noticed is that most has them at "mild" settings, at best. I have some kelford 280/276 going in so, wanted to know if someone could tell me should I set up for early mid or top end cam settings based on my current set up and TUNER.
To properly set the cam gears you will need a dial bore indicator and a degree wheel. There isn't just set spot to set the gear. There are several factors that can change the geometry of the timing such as surfacing the head and block.
check this out, it has some valuable info.
LINK
Wow, lots of info. I was more leaning to adjusting for more top end for more mph down the strip, but there are so many things to consider at same time. I guess this is going to be a marco question.
