1G Cam/Crank Shaft Position Sensor from Turbo work on NT
TheronBorslien
86
Nov 18, 2010
San Diego, California
im not getting spark, and im pointing this part out. i have the repair manuel, so i did most procedures, but my main question, can i put a turbo one on my nonturbo?or does it need that extra boost of voltage to really make the difference?:pray:
yes you can put the turbos cas on the nonturbo. i had a similar problem not to long ago and it turned out a wire was broke on my sensor.
sick! i love this website. :) i was told moisture got into my old one, and i see what looks like rust under the little plate you can unscrew. is that correct?
