Resolved Cam Angle Sensor issues.
92gsxecl1pse
86
May 9, 2009
Columbus, Ohio
I was driving my car last night and did a pull, and then the thing completely just died out. I checked under the hood and noticed that the Cam Sensor plug has cam off, i noticed that its still loose and not snapping, and come to find out that the clip itself is busted and wont snap it. So i was wondering If i buy one of the adapters that i see advertised at the top of this site, for 2g 6bolt swaps, will it work on replacing or am i gonna have to splice some wires in with a new connector. Ive got it ziptied on for now but usually after 1-2 pulls the CAS just keeps popping off.
Any help is appreciated, Thanks
Just hit up a Junkyard and look for a 1g! Even the non turbo ones have them...90 is different from 91-94 though.
Goood luck
Make sure to solder the new connector on as oppose to using crimp connectors and put some shrink tube over the splices as well
