cadillac ats brembo on a 2g.
rival
246
99
Dec 12, 2004
aiken, South Carolina
So I am going to be getting hooked up with a set of brand new brembo brakes from a cadillac ats.... I am curious as to weather there is any way I can make them work on a 2g. The rotors are 17" and the caliper is a 4 piston so I will need to run 19" rims I am guessing. The brakes are free so if I can make them work that would be awesome! anyone have any suggestions aside from just buying the correct ones?
I just did a google search for Cadillac ATS wheel size and they come with 17x8 or 18x8 wheels, I assume the ones that get the upgraded Brembos get the 18x8 size wheels. I would be most concerned with getting a caliper brackets and rotors that will work vs wheel clearance.
well getting the rotor and calipers is not a problem, I will have to make a bracket for them to bolt up. just curious what else I will need to address if I go this route.
I plan on running an upgraded master cylinder to go along with the upgraded lines and caliper, its just a track car now so i think i will play with it a bit and try to make it work, and if not maybe i will sell them and use the money toward the correct set.
