buzzing noise!!!!!!
happened to me when i had bad spark plug wires.... its interference coming from somewhere
Check your headunit ground and your amp ground. I had a buzzing sound similar to that and it was because my headunit wasn't grounded properly.
Did you install the cd player yourself? If you did, did you run a new ground wire?
If you didn't, don't worry, you have enough support here to talk you through it.
As mentioned, you could also have a bad ground with the amplifier. Did you scrape away the paint from the grounding wire location of the amp?
make sure your amp power wire and your rca wires aren't running to the trunk next to each other. run them back on opposite sides of the car.
also, you didn't mention which speakers the buzzing was coming from. the speakers hooked up to the amp or the speakers hooked up to the headunit?
