Buying a 94 laser rs turbo
Blu90GST
172
Sep 10, 2013
East Peoria, Illinois
Long story short the guy says the timing belt broke and bent some valves, the 94 has the 7 bolt. I have a 6 bolt sitting in my garage that I could pull the head off of. I also have the 7 bolt head bolts and a head gasket that I could put it all together with. My question is that I read that head studs will work in my case if they're for a 7 bolt. Will my head bolts work also? Does anyone know where I can find the washers that sit in the head where the bolts go through if so?
Id send the head to a good machine shop that knows what theyre doing to fix up whichever head you use before installing. Also, factory 7 bolt head bolts are TTY- torque to yield- and by design stretch when torqued down, and are not reuseable, so either get a set of ARPs or get a new set of factory bolts, but I recommend ARP since the price is negligible and its a better setup anyway.
