Built motor and now what?????
4g63telantra
454
Dec 10, 2004
Toronto,
Soon my 4g63T will be done at the machine shop with new pistons, cams, duel valve springs and a few more stuff.
I will also be having my DSMLINK hooked up as well once the motor goes in.
My machine shop tells me to drive a few K's on the highway with the rpm's up and down to work in the motor.
What I would like to know from other people who has had a built motor is...
Should I take it on the highway to work in the pistons rings (non tuned) or should I run it hard to ture with the DSMLINK? (motor not worked in)
So drive non-tuned or drive motor non-worked in???
I'd say hook a logger up and make sure your timing is good when you do the break-in pulls, and from then on you can make fuel trim adjustments while you are driving no problem.
From what I have been told you are supposed to take it easy for a certain amount of miles I think it is a hundred.
with me,im gonna rev it up and down for about 20 minutes since piston rings seat almost immediatly.but id listen to the shop since they built it,and if there was a problem,it would be on them.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
