cwriley
- 85
- 1
- Sep 30, 2010
Fort Mill,
South Carolina
after putting a new stock motor in my 1g eclipse i tore down my old heads. I want to built a turbo engine. i know i have to get a 4g63t block ecu injectors etc. etc. but i am wondering if i can re-build my n/t heads to fit a turbo block, will it fit the same? (planing on building a 2.3l turbo bottom end)
and also cam sizes, i read up and decided on hks 264 cams but when browsing there are hks 264 cams with different lifts sizes, what size would i need, i want to built a descent turbo motor but not a drag car just something to open up and hawl a on the weekends
ideas and thoughts are appreciated
. but i guess i will start with engine. i have tried to read up on forums to find a descent motor build, i WANT A TURBO so bad because the n/t just isnt fast enough for me. im thinking about doing a 2.3l stroker eagle rods, wiesco pistons ( not sure if i spelt that right) eagle crank and new bearings, upgrade cams, valve springs lifters and rockers, port and polish the heads 3 angle valve job, skunk2 camshaft gears, i know i would need to upgrade fuel pump and injectors and probably bigger fuel rail. its mostly all in my head right now just gunna start buying parts each month and put it together slowly.
