99gst_racer
Moderator
- 12,010
- 1,706
- Apr 5, 2003
Coloma,
Michigan
I just started to piece everything together to build a 6-bolt motor to drop into my 2G. I've been researching and pricing out all of the internals for the head and block and I came across a few questions.
My goals for the new motor are you be around 450 whp. I dont want to get too greedy.
My parts of the head can I re-use?
I am obviously going to replace the cams, valves, guides, and stem seals. But what about the springs, retainers, locks, etc? I just need to know what part won't handle the 450WHP and 8000ish rpm revs....
I've talked to a few of my high-HP DSM buddys, as well as a couple good machine shops, and I decided to have the block o-ringed. Would you guys also recommend have the head o-ringed too, or just the block?
Regaurding pistons - I have narrowed it down to either JE or Wiseco. Do you guys recommend one over the other?
Also; this car is going to be a street driven car (highway monster). Do you recommend an 8.5:1 or a 9.0:1 compression ratio?
This is going to be a fall/winter project, so I'm in no hurry with it. I'd rather first get all my ducks in a row and have everything well planned out before I make any purchases. Thanks in advance.
But, yes, that is the profile that I'll want/need. I'm not yet sure if I'll need adjustable cam gears, but if I do, I have my eye on the Fidanza's.
