BS belt install
Take the plate off. Or eliminate the shafts all together. Do you have the timing belt hydrolic tensioner off?
You have to take the crank sprocket off with a 1/2 drive ratched or impact works best.
With the crank position sensor off you can slip (and twist) the belt behind the backing plate (called sensing blade) while rotating the crank a little each way. I've done it many times. You don't need to take off the plate.
Turn the crank far enough so the belt can clear the sensing blade part that sticks out. Then pull the belt out enough while doing the same thing by turning crank the other way (ie. keep belt against sensing blade part that doesn't stick out while you rotate crank so belt can make it around and off blade). Removing the CPS helps give enough clearance to get the belt out from behind the plate.
Yeah you don't have to but with the condition of your timing cover I would and clean it off. I see you already have oil and stuff on the belt. You don't want that thing dryrotting and breaking and getting wrapped up in your timing belt. I've seen it too many times where an oil cover BSB is the cause of a jumped motor.
