broke oil line to turbo, how do i get a new one?
jlgeclipsegsx
136
Jan 4, 2011
Moorhead, Minnesota
Ok, i had to replace my head, and when i was removing my turbo i broke a line and i was just wondering what i couild do to fix it, most likely buy it but i looked online and couldnt find one. I have a picture of the line.
To add, I have tried taking if off the turbo but i cant.
You can get it from the dealership or vendors, that may carry it. You can also just go to the parts store and get the metric brake line in a similar length and bend it to fit. The 3rd option is just to get a braided steel -4 line with fittings.
if youre talking about the 3/16 inch oil line with flared ends you can pick up bulk line at autozone, napa, oreilys.. any of the the "auto parts" stores... they have lengths ranging from 6 inches to 60 inches.. ends already flared with fittings on them and then you just bend them into place.. they cost about 10 bucks
Vice grips are the way to go getting that out. You will usually just strip it with a line wrench. As for the line size, it is not a 3/16 it is a metric. The standard will fit, but be loose.
Measure the length of line you need (there's a connector somewhere under the turbo; the line is not all one piece from the filter housing) and buy a section of 1/4" brake tubing from a parts store then bend it as needed. Fixed for $6.
Best way in my opinion to remove that line from the turbo is to cut the line about 1/2 inch from the fitting and put a 12point socket on it... then its just a matter of unscrewing it.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
