Brakes lock up easily
Myristica
58
Jun 26, 2011
Antwerp, Europe
Hi all,
My car does not have ABS, and everytime I have to push the brakes a little bit harder than usual they lock up and I slip. I have the feelings it's either all wheels standing still or only the ones in the front because the car doesn't brake out. There are braking fluid leaks. Could it be the EBD? How can I test this?
thanks for your input
The fluid leaks are the problem. When you apply the brakes, equal pressure is applied to each caliper. The leaking line decreases the amount of pressure to that wheel. The wheel that isn't leaking stops first. The other wheels are still rolling.
No, I think it are both front wheels. The car is not pulling to any side, but I get the feeling I'm not able to steer it in any other direction. That's why I think both front wheels lock up, If it were the wheels in the back I think the car would break out in a spin or slip.
The tires are good, from a quality brand. They are 17" and wider than the stock wheels, so I already should have improved my friction with the road..
But my winter tires are on the original 15" rims and I experience the same with those on the car.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
