Brake Job Time
WSU99GSX
525
Mar 16, 2004
Peoria, Arizona
Just got my rotors, brembo rotors, and come ceramic pads. Just wondering how hard it is going to be to do all four corners, and about how long it should take me. Also anything I should be aware I might run into? Trouble wise? Thanks!
brakes are easy as pie, only suggestion i have is to grind off the rust with a wire brush or something on the hub behind the rotor when installing new rotors so the surface is flat.
I had a real hard time getting my front rotors off. Do yourself a favor and soak them with some PB Blaster a couple of days before starting, apply it 2 or 3 times. Also when you install the rotors put some anti-seize on the hub beforehand, if you have to remove them again it will make it much easier.
