jgouds
- 36
- 1
- Jun 2, 2014
Calgary,
AB, Canada
Hey all,
I did a bunch of research prior to tackling this job and had the Haynes manual watching over me - I replaced all the rotors and pads on my 1g yesterday and now I have little to no braking power. Here's what I did -
replaced brake pads and rotors (I opened the bleeder when pushing in the calipers)
pumped brakes and topped up reservoir with DOT3
Bled the brakes in the order: passenger rear, drivers rear, passenger front, drivers front
Now pedal travel is all the way to the floor before brakes even start to be applied. When I pump them I get some pedal feel back - but it goes away quickly. I've rechecked the fluid reservoir and it remains full.
I understand that the symptoms point to a bad master cylinder - I was fairly sure I took the precautions to prevent damage to it.
One more thing - I went out and tried breaking hard to see if it was just an issue with the pads or rotors needing to be worn in. Felt the rotors after: 3/4 were hot while the drivers front was still cool to touch. Anything that might cause a caliper piston to seize after doing work like this? I greased all the slides with silicon grease so it shouldn't be catching on those. Also - is there anyway to diagnose a bad master cylinder?
Apologies for the story - just trying to be as descriptive as possible.
