brake fluid
superdaddy
38
Sep 16, 2004
Madison, Wisconsin
my brake fluid in the resevior dissapears in like days......... every week i have to refill it........ i dont see any leaks on the groud...... i have no idea where its leaking, help........ dont want to keep buying brake fluids
I had the same problem before and found out I had a pinhole leak in a brake line that only leaked(squirted) when I depressed the brake with a good amount of pressure and it sprayed directly on the ground without leaving any drips on the car itself. Have someone sit inside the car and press hard on the brake while you check each wheel.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
