brake fluid leak
rza808
81
Feb 14, 2010
Makakilo, Hawaii
i am leaking fluid on the ground at the driver side leak is coming down and driping from the a-arm. I am hopeing its not coming from one of the lines above the a-arm but i have a feeling its coming from the booster or the master. just wanted to know which is a more common leak cause i can tell where it is from and i dont want to tear everything out just to see its the master.
And if the booster is leaking where on the booster will it leak from?
Start at the a-arm first by taking the wheel off and see if the leak is there. If not then it's coming from further up. I don't think the fluid would follow the lines if it was dripping from the brake resivore.
i think i found the leak inbetween the booster and the master and driping down the fire wall and on to the a-arm, if that is where it is leaking is it the master or the booster?
It's prob. going to be the master, you'll need to clean the fluid off and try to find out exactly where it's leaking at.
