brake boosting with nitrous
blktalon3
Supporting VIP
548
79
Aug 30, 2006
Stanford, Kentucky
I'm thinking about getting nitrous to help with spool up and I'm trying to get as much info as possible. I was looking at the Zex wet turbo kit and was wanting to use as small as shot as possible just till I get into boost. My main question is can you use nitrous when your brake boosting? And if not how do you launch using nitrous with an auto?
If you have a link you can control the nitrous to turn on at a certain rmp and turn off at a higher rpm. I have heard people spraying at the line to build boost in order to launch.. you would need to hold the brakes.. give it some gas and hit the button. Before attempting to use nitrious please make sure your trans has all the mantanance done and upgrade the trans cooler.
