Karma
- 142
- 2
- Mar 12, 2006
Sherwood Park,
So I took my pedals off the other week to weld, I found it was easier to just remove the brake booster. Upon installation I was reading through my manual and it has a spec. for brake booster pushrod and master cylinder push rod clearance. It should be 1/32nds to 3/64th's. When I push my booster pushrod in it travels about 1/4'' before I can feel it contact the master cylinder push rod. It says to adjust this you hold the booster pushrod with plyers and turn an adjusting screw in or out as necessary. Problem is I dont have an adjusting nut. Whats the deal?
Here is a picture of what im working with.
And info would help.
Sean
Sean
