Musashi450
- 94
- 0
- Jan 3, 2003
Champaign,
Illinois
Does anyone have experience with diamondstar motorsports braided oil returns? I received a 45 degree fitting and a 180 degree fitting that screws onto the adapters (which bolt to the oil pan and the bottom of the turbo) The problem though is that the 45 degree fitting goes out further then the bottom of the turbo and causes the tubing to kink when I force it into the general place. I can't actually get it to screw to the adapter. I'll attempt to take some pictures if this doesn't make sense. When I had the factory line on it was also a bi*** to get into place and was leaking (why I switched). Is this normally a pain in the ass to put on or am I doing something wrong? Thanks
