bov recirculating tube
home depot. i believe its 1-1/4 inch ID vinyl tubing. $3-4 per foot. you can use 3/4 ID (or 1" ID i forget) pvc elbows for joints (use hose clamps).
Otherwise for oem... find a part out, or a JY or classifieds.
Take your bov to Home depot with you and check fitment of everything.
I did the hardware store method. holds up great. and looks clean
You can get this hose from NAPA, works well.
Just use the part number
I got this for about $3 at Home Depot. It takes a little convincing to get it to slide over the BOV and recirculation pipe, but it works great. Not to mention your not limited to the stock BOV location since the hose is flexible.
glad i ran across this mines falling apart too. looks like a trip to home depot for me. and your right its a pain in the *** to find a stock one
Was that 9277 napa hose used as a stock replacement hose on your 1g? I'm looking to replace the stock recirculation hose on an unmodified 1g. Also, what car was that sourced from? I'm having trouble cross referencing the part number. Thanks
  • Wanted 6 bolt NT water pipe
    • chrisman287
