Recirculating BOV
No, recirculating it will quiet the noise A LOT. Get a piece of rubber hose like you going into your radiator. You can probably get this at a checker or autozone for like $3. You have to connect into the nozzle on the side of the air intake with one side and on the BOV with the other side. Clamp both of them down and your all set. This is assuming you have an aftermarket BOV and air intake. If its stock then I have no clue.
If its stock it is already recirculated and you should leave it that way. There should be a hose that goes from the BOV that recircualtes back into the intake, if its not there it should be replaced, unless you have a MAFT and blow through setup.
Very well put.
http://www.dsm.org/
Read it,read it again then read it some more.
It will more than likely be VERY usefull to you.
There is tons of good/important information in there
