bov pics
baxsom
480
5
Jul 10, 2004
san antonoio, Texas
does anyone have a picture of what the inside of their BOV should look like at idle
when my engine is running i can see the rubber seal if i look inside the vent of the bov and then if i rev the engine i can see the bov close tight then as soon as i let off it opens back up
low boost like 1 to 5 psi i get a little flutter then it goes off properly
high boost 6-10 psi it blows off like it should
is that normal or should it be adjusted so that it is closed at idle
I think its supposed to be where you dont get any flutter..... Atleast thats the way it is for us 4g63's. The type S has to be adjusted just right. :thumb: :talon:
but there is no way to recirculate on a 420a engine is there?
i decided to try some experimenting
i read a lot of pros and cons of hooking up the lower nipple to the compressor housing
so i figured wtf why not
amazing
the damn thing works now
even at low boost
like 1 psi
i get a poof of air sound
not the kicked the dog high pitched flutter that i was getting
at higher boost 5psi up the max i am pushing i still get the whoosh instead of the flutter
and it holds steady at wot
now that it is working it will probably blow the whole car up
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
