bov line to intake mani.
2gTalonnn
55
May 27, 2009
SD, NB, Canada
hey guys right now my greddy bov is installed like this. WG t'd off to MBC and BOV. i have a flutter so i want to have it one simple line to the IM to the BOV. my question is does it go to the A1 nipple on the intake mani? because there are 4 nipples. A1 A E P i think. can anyone help
is my bov even hooked up correctly? i thought it had to be past throttle? well mine is not. i feel like it needs to be hooked up to the intake manifold!?
Do not tap into the bov line. It should be a solid vacuum line from bov to intake Mani. Install mbc between wastegate and the jpipe nipple. If aftermarket pipes don't have a vacuum source than u need to add one too the jpipe or turbo compressor outlet.
yea. the person before me rigged it that way LOL. well i want to have the bov going to the intake manifold but, on the little nipple by the coil pack has i guess the boost gauge and fpr there. so where can i hook this up at?! someone mention the P port on the throttle body.
i have a 1g intake manifold and it does not have the nipple where the 2g is located mine is by the coil pack. but they are already hooked up to a boost gauge and the fpr. my question is can i hook it up to one of the nipples on the throttle body IE: A2 A1 E P? let me know
I have never heard of hooking it up to the P port. But i have a 1g manifold too and my bov is hooked up just like that picture above illustrates. I can understand how you could over look it though, it's kinda hidden under the front of the IM. I would take another look at it and examine everything. Even use your hands to feel for anything, it's only a little brass tube that sticks out.
