2G Bought a 2GB GST. Multiple Codes
redGT
Sep 22, 2007
Tyrone, Georgia
Hello Everyone!
Just got a 97 GST and it's a bit of a basket case mechanically.
The car doesn't rev clean or hold idle and is throwing the following codes:
P1105-Fuel Pressure Solenoid
P0120-Throttle Position sensor Circuit A
P1400-Manifold Differential Pressure Sensor
P0443-Evap Emission System Purge Control Valve
P1105-Fuel Pressure Solenoid Malfunction
It was suggested that the MPI/MFI relay could be bad causing most of these issues so I ordered one and will have it soon.
Is there anything else I should be looking at?
Thanks
UPDATE:
I ended up buying a new Throttle Position Sensor, Fuel Pressure Solenoid, Manifold Differential Sensor, and MFI/MPI relay as they all looked original.
Swapped everything in the car and drove it 50 miles yesterday and the car now drives perfectly.
I reset the CEL and am gonna put some more miles on it this week to see where i am in terms of error codes and will report back.
