Resolved Bosch 17025 wideband O2 connection?
fisher83
89
Aug 23, 2013
Tacoma, Washington
So I looked around a little and was wondering on the bosch 17025 wideband o2 sensor I have, is the yellow wire the signal wire I need for the stock ecu to read from? I have ms II on the way from symtech labs soon....just need to get by on the stock ecu and break in my new motor before I start my megasquirt quest...oh almost forgot the o2 sensor is for my wideband afr gauge....
You need a wideband controller; but these are often built into gauges now (e.g. the AEM UEGO, Innovate MTX-L, etc.). What kind of gauge do you have? If it has a controller built-in, the gauge (not the sensor) will have a wire for you to connect to your stock PCM, and later your MegaSquirt ECU.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
