bosch 044 pump
my4ATEurV8
210
Jun 30, 2008
wausau, Wisconsin
just a little short on cash right now so i was wondering if i can run a bosch 044 fuel pump without an aftermarket intank pump? can i run the 044 fed by the stock in-tank pump, or even without an in-tank pump? ifso how do i do it?
this is for a 95 tsi awd
You can use the 044 with the stock intake, no problems there. If you want to keep the 044 external without an intake pump you would need to "sump" the factory tank. You should have plenty of fuel for your setup with the 044 feed by a stock intank.
you can also make atube that fits inside the tank that takes the place of the stock pump with the sck on the end and run it external.
will running the 044 fed by the stocker deliver more fuel than a single intank 255 walboro
