Boost spike issues...
Cool Mr Steve
553
11
Jul 18, 2004
Spanaway, Washington
I have a Big16g with (I believe) a standard size wastegate flapper. I ported the wastegate opening and the o2 housing before installing it. I have a Hallman MBC (the one with the little bleeder hole on it, I'm not quite sure if they all do...) and I really don't know what the boost is set to. My boost will spike all the way up to about 23.5 or so, settle around 18-19, and by redline seems to drop to around 17 or lower. What do you think may be causing this? I know a lot of people have problems with bleeder type MBC's, but even though it has the little bleeder hole, it's a ball and spring, isn't it?
I don't know about the Hallman MBC, but I do know Big16gs that are internally gated are known to boost creep. I had an Evolll 16g with ported 02 and wastegate with the larger flapper, and mine boost creeped as well. I would say look into a 38mm external. Also, colder climates, like in Washington, will be more prone than warmer areas.
yeah try get an external or you could put the boost contrioller down so that when it creeps it won't be that high
Tone the MBC down to like 16psi or so, that should help, and YES switch it out to an external, because the internal WGs will boost creep under heavy loads.
My problem is not with it "creeping," but rather with it simply spiking for a split second. I hit about 23-24 for under a second, then it settles. I don't want to get an external wastegate. I understand what causes the creep issues that so many people have, but it seems much different than what I'm experiencing. Does anyone else have any other input?
By any chance, your clutch isn't slipping is it? At WOT, pref 3rd gear, see if your rpms jump and come back down the same time as your boost.
I have an evo3 with no creep at all and its internally wastegated. But my turbo did spike with a MBC that my mechanic made me. Ive heard a lot of top brand MBC cause spike. My brother has the nice greddy profec controller and is very nice. It always hits the boost it should.
I'm thinking about getting either a different MBC or a 34mm wastegate flapper. Does anyone else have an idea? It seems like my boost is reverse creeping. It creeps downward. Grrrr...
You're right that this problem seems less like a creep issue and more like one of poor responsiveness from your MBC. Are the lines from the boost source to your MBC and to the WGA reasonably short and unobstructed? I would also check the integrity of these lines, as a leak would kill your controller response as well. I'm not sure which Hallman you're describing, but I have the Pro model, and it performs rather remarkably.
EDIT: Just saw that this thread is almost 5 months old! What'd you dig this one up for, fourreGsixty3?
