boost problems after new turbo install
So your saying if i run a straight line from the compressor to the wastegate and then tee that line off to the solenoid and then solenoid to the top port of the wastegate that the pressure that is being generated will help keep my wastegate closed?[/QUOTE said:
Yes, profec b can handle up to 30 psi hooking it up like that, that's been my experience with profec b. I haven't ran a profec b for a while but I think you will have to switch the little switches on the back of your boost controller accordingly if you hook it up that way.
