DiamondStarCar
- 60
- 2
- May 7, 2004
Mansfield,
Texas
First off, I don't want to waste anyone's time by not searching, so I have done so. I found many articles about boost leaks, but I can't perform the test until tommorrow because of my final exams at school.
--Here's the problem:
I turn the car on and it runs great...no CEL, no surge, no misfire. Free revving to about
3k shows no problems either. However, when driving, under boost at WOT, the car will studder at about 2k rpms....up until this it drives normally. This is what leads me to believe it's a boost leak. Before I get in trouble here, I just want to mention that my boost guage reads 10psi max even at WOT (usually get 14-15). I had a vented HKS bov, but put the stock one back on and the problems continued. I read about 15 vac. at idle, even before the car warmed up. Any other way to do the boost leak test than the pvc pipe and bicycle pump? It should also be noted that the car drove perfect, then this problem started after parking it for 2 hours to study.
I want to apologize in advance because I know there are literally countless threads written on this, but none included the weird HARDCORE vibration my car gets when I go WOT and the turbo is done spooling.
--Chris....95 gsx
--Chris....95 gsx
