Boost leak, pressure drop, and Ebay datalogger installation
Verticaljump1
147
May 8, 2004
cheyenne, Wyoming
How much pressure drop is there when you install a 2.5" uicp/blow thru set up? Can boost leak account for a 2500RPM idle and taking 15 turnovers to start? Where do the 3 blue connectors go for the EBAY datalogger? I know some of you have purchased the cables off of Ebay, where the hell do the 3 end connectors go. My disc drive doesn't function so I can't read the instructions on the disc. I know it plugs into the diagnostic port, is that located on the far lower left corner of the driver's side? Which metal tabs to the connectors go to? If you guys could tell me which color of wire goes to which tab that'd be great. Thanks for any help you provide and have a nice day! :) :dsm:
Make a boost leak tester and find out were your boost leaks are at.
for datalog,
colored wire goes top left
ground 1 goes botom right
ground 2 goes 3rd tab at botom right
