1SicDsm
- 106
- 1
- Sep 21, 2005
Visalia,
California
Hey everyone yes I allready did the search i found some good treads but no help, Heres the problem i did a boost leak test and found boost leaking around my injectors. So i went to mitsubishi got some seals ordered and installed them turned the car on and darn same thing the engine shaking and the vacumm kinda low and jumpie, so I went back to searching and found a link to the fuel injector clinic and ordered myself some high boost seals go back and turn on the car again and what do you know same thing, I know its around the injecors because when i tested it i pumped 16 psi in the system and hold the injecor down and the air stops leaking but once i let it go again leaking. I took it to the dealer and told them to fix it and whatever it cost i would pay he said to find a tuner shop cause all he would do is fix it back to stock. They thinks its too modded thats the fist explenation they have, all i have is intake and BCS mod exhaust, and im getting really pissed at this point
ANY help is appreciated
. ANY help is appreciated
