Texas_GST
- 0
- May 2, 2008
Lubbock,
Texas
Hello guys. I have searched the links for a while now but I can't seem to find my problem on here. I own a '97 GST. The previous owner had installed a Blitz compressor bypass valve, manual boost controller, and boost gauge. The problem, or at least what I think is a problem is that the gauge and boost controller are plumbed in together. My gauge does not show vaccum, just boost. Here is a pic of the T-fitting that is installed.
The black vaccum line to the left goes to a line directly behind the intake manifold (passenger side) where it branches off into two lines. The black vaccum line that goes directly down goes to the boost controller, which the output from the boost controller then goes to the wastegate actuator. Is this correct acceptable? I know that the line in the picture below is the one that I should use for this right?
